Fuel polishing system
Brad, I put a diesel fuel polishing system on my 410. I used a Walbro continuous duty fuel pump. Continuous duty is important. I also used a Racor fuel filter with a clear bowl at the base. The system is easy to install, took a weekend, and cost about $350.00 (I think - was a couple of years ago). I mounted it on the bulkhead in the port stern locker. I put a pick up tube in the fuel tank using the return-fuel fitting from the engine. It is complicated to explain in this note but here's the simple explanation. I screwed a new bronze fitting into the threads on the tank. In the center of the bronze fitting I put a plastic pick-up tube that went to the bottom of the tank. That tube connected to the hose that led to the Racor fuel filter. The diesel fuel that returned to the tank from the engine entered the bronze fitting and flowed back into the tank between the fitting and pick-up tube (the OD of the pick-up tube is smaller than the ID of the bronze fitting).The fuel to be polished entered the hose at the bronze fitting, travelled through a shut-off valve and into the Racor filter. Then into the fuel pump. It entered back into the fuel tank through a fitting plumbed into the fuel-fill hose that connects the fuel-fill fitting on deck with the tank.Simple, effective, and relatively inexpensive. Go on-line, type in Walbro for a review of pumps, type in fuel polishing for more ideas on pumps, set ups, etc. But it is far less expensive and probably better to install your own. You can tailor it to your space and needs. Good luck,John
