C
Curtis
Hello fellow Catalina Owners!I just bought a 1975 C22 and noticed that there is a bolt under the forward port seat that goes through the centerboard well. It is my understanding that one tightens this bolt while sailing to prevent the centerboard from slamming into the hull in a seaway. My bolt is corroded to the point of not moving (It is in the loose position). I am not sure what the bolt looks like on the end that is in the water. Can it just be loosened by force or what. Should I order a special "keel bolt" (if that is what it is even called) or can I just use a stainless steel bolt that is the same size. If anyone out there has ever had to deal with this part on their boat I would sure appreciate some guidance. I am aching to go sailing, but I really want to resolve this so as not to jeapordize the hull.Thanks in advance,Curtis
