Frozen injector on Yanmar engine 3JH5E
Jun 12, 2013
213
Hunter 40 back creek
Does anyone have a tool to remove this fuel injector it ie frozen. 3JH5E engine or know where I can purchase one
I wa told that the tool screws on to the top pipe threads and you use a slide hammer carefully to free it up!
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
That's about all you can do spray with wd-40. And pry out. Use what's left to make a compression testing tool. You will understand after it's out.
pateco
Aug 12, 2014
2,207
A leaking injector can build up a lot of carbon deposits that make it difficult to remove. A trick I learned with my Mercedes Sprinter diesel, was to soak the carbon deposits in carb cleaner to break up the carbon, unti it is cleaner. Once that is done, soak the stuck injector with penetrating oil (PB Blaster, Kroil, etc), loosen/remove the injector retention screw(s) and then attempt to start the engine. The compression of the piston helps to force the injector out without damaging it. Do this one injector at a time, and leave the fuel lines attached until the injector is loose to prevent fuel leakage. Clean/replace one injector, reattach the fuel lines, and move onto the next one.
Here is video of my leaking Mercedes injector
Here is video after loosening the hold down bolts and restarting
The injector came loose, and was easily removable. It still had lots of carbon to be cleaned off before I reinstalled with a new copper seal washer.
5,656
Oday 322 East Chicago, IN
The injector came loose…
Man, I was expecting to see the injector fly out like a projectile :yikes:
Good hack though…I guess that is why you leave the fuel line attached:cool:
Greg
