Dave Viglierchio
I have found a lot of corrosion under the bales on my 1983 vintage C-36 boom. Unfortunately it is as bad as the surveyor suggested, contrary to the seller's thoughts at the time. Does anyone have an opinion on replacing the boom? I'd like to remove the hardware and put it on a new extrusion which is available from Catalina. BUT...I've found most of the screws and fasteners are frozen. Even using an impact type tool the screw heads just round out. Is the next step to grind the heads off and drill or tap and use an "easy-out" for extracting the screw shanks? The bolt on the aft end is frozen too and I don't know what it is attached to inside the boom. Or is there a good reason to buy a whole new boom complete with all fittings? Is there an aftermarket boom available that is either more economical or better performing or both? The boat is used for sailing in SF bay and will do some short coastal cruising soon. Any suggestions would be appreciated greatly. Thanks.
