Front Running Lights
Dan
Jul 26, 2006
190
Hunter 420 Stamford
I have no power in my Front Running Lights !
The rear light and compas light work fine
The wires run into my bow pulpit , but from there I cannot follow where they go ? I have found 1 hot wire from the panel that goes into a bundle
on top of the cabin stairs ?
any ideas , should I just run another pair of wires up front ?
Great summer sailing here in Nova Scotia !
Dan Allegro 1240
May 12, 2009
57
If I remember correctly, from the pulpit tubing they come down into the anchor locker and then down the boat on the right side, behind the
board at the joint of the hull and deck.
Mikko A.
May 9, 2011
1,000
On my vega the wires are run inside the deck, exiting inside the anchor
locker. there are 3 wires and only 2 are actually needed so one can be
used as a spare if need be.
