From too little to too much?
G
Gene B.
After a couple of years of sailing/motorsailing on the Mississippi River I decided to go from a two stroke to a four; from 8hp to 15. The four stroke is considerably heavier,around 130lbs and also has a high torque gearcase/10" prop. Mercury Bigfoot longshaft. I have a new heavy duty mount(91/2") travel compared to the old one which was 13" and spooky. Has anyone had any experiences to share because this is going to be a major job. ie. laying in alot of fiberglass at the lower drain area to accept the 3/8" bolts that I feel this mount needs,plus backing plates to lower the stress on the hull. Will this screw up the center of gravity on this boat? A 15 hp 4 stroke weighs the same as a 9.9 4 stroke. Any ideas will be greatly appreciated. I'm keeping the 8hp just in case.
L
Larry Mongeon
Same Gene
No pun intended. I have a 1974 H25 with a 15HP merc4. I have been using the factory motor mount with no problems. The one thing I did was order a new " Work Prop " (thats what merc calls it) designed for sailboats or displacement hulls. It is a perfect combo for my boat. I also have electric start and charger so it makes life real easy. I can push hull speed at approx 1/4 throttle and there are no stress cracks or problems on transom. Hope this helps. enjoy your new iron genny
Dec 2, 1999
15,184
That what we had on our H'25 too.
Gene: We also had a 4 stroke Honda 9.9 on our H'25. Worked well with the stock mount. With the additional weight I would think that a new mount would be in order. I would want this just to make lifting the engine easier. I would use a largeest piece of plywood 5/8-3/4" that will fit. A good coat of varnish or epoxy in case it gets water or moisture would be a good idea too. Like Larry said the stock mount should hold the load if you do not open it up, but I think your idea of a larger mount is prudent.
