From seawater to drinking water, with the push of a button
JRT
Feb 14, 2017
2,059
Sounds cool, rate of 0.3 liters per hour, and requires only 20 watts of power per liter.
Jun 11, 2004
1,829
Oday 31 Redondo Beach
That looks good. I know they are working on it but they are going to have to get their output and efficiency way up.
"Their prototype generates drinking water at a rate of 0.3 liters per hour, and requires only 20 watts of power per liter."
Fascinating research.
Can hardly wait till ready for Prime Time.
I think the report has some mismatched units there. Watts are a unit of power at a specific time, not power used per time period. I’m guessing they either mean 20 watt hours per liter, or 20 watts continuously while making the 0.3 liters per hour (which would be about 67 watt hours per liter).
For comparison, a Rainman DC desalination water maker is spec’d at 26-34 liters per hour and 410 watts. That’s about 14 watt hours per liter.
I guess one advantage over the existing systems would be that it’s a lot easier to generate 20 watts throughout the day than to generate the 20 watts and store the power until you have enough saved up to run the bigger power draw.
JamesG161
Feb 14, 2014
7,912
Hunter 430 Waveland, MS
That is the removal of salts rate.
Do not forget the reverse electro-chemistry to return unit back to starting point.
If I knew their power efficiency, that reversing could be included in the overall power use.
But for 100% efficiency ....
Double their number.
Jim...
PS: Another winner from DuPont, now Chemours. Starting with the Teflon® molecule.
Nafion
Found the actual energy consumption in the abstract of the source article - “The portable system desalinates brackish water and seawater (2.5–45 g/L) into drinkable water (defined by WHO guideline), with the energy consumptions of 0.4–4 (brackish water) and 15.6–26.6 W h/L (seawater), respectively.” So the report must have meant 20 watt hours per liter. I guess that’s not terrible considering its portability. A boat where permanent installation of pumps and filters is possible is probably not the intended use right now.
Likes: Thaniel
JRT
Feb 14, 2017
2,059
Neat options but I was wanting more capacity and the original post was no filters, so in theory always available.
Jun 11, 2004
1,829
The item in the link says it boils water. Nothing about desalination.
The OP is talking about desalination, not filtration or purification.
I suppose you could use the boiling water to distill fresh water from seawater but I don't think that would be very efficient.
