Or, maybe it's a primary benefit. You find things like this:
As they say in the lottery ads, "Just Imagine!". Full battery current running to ground though the air intake housing which contains an oil soaked piece of plastic foam. This is why every battery should have a fuse right on the terminal post.
The Compass Marine Services (Maine Sail) guided electrical upgrade is off to a good start. The strange old battery switch had a small hole for a shaft that was too large for the pilot of a hole saw. I made this template which I fastened to the panel with the mounting screws for the old Perko switch. It also had template holes for the new switch's mounting bolts.
Thanks to Maine Sail for the tip of running the hole saw backwards. Cuts beautifully in the Plam with no chatter or chipping. The hole in the plywood guided it in perfectly.
I'm going to just fill in the old switch markings with an artists brush and black paint.
I lucked out on the hole for the Victron battery monitor. It fits perfectly in the hole left by the discarded analogue voltmeter. I'm going to put a warning light in the old selector switch hole below and wire it into the relay contact on the Victron for low battery indication.
Now this question: After removing the old and corroded ground buss bar for replacement with a new Blue Sea bar, will I be able to find EVERY single ground wire in this mess?
It didn't look quite that bad before I cast everything loose, honest.
