Frigoboat refrigeration
jmoir
Apr 16, 2013
10
beneteau 40cc rothesay
I have a Frigoboat system in my Oceanis 40cc. It is powered with 2 group 31 140 amp hour deep cycle house batteries. The system does not cool adequately, starts & stops about every 2 minutes. The controll says low voltage ?? I have checked all connections & cleaned the radiator on the compresor but no improvement. would adding more battery capacity help??
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
Check the voltage at the unit while it is running and the batteries fully charged with a meter. If it is low follow the wires back checking each connection. I assume it worked correctly at some point and the wires are the correct size for the load. If it is a new install make sure you have the correct wire size per manufactures recommendations for length of run.
