frig/freezer lid latches
930
Hunter 410 full time cruiser
I'm tired of the plastic latches on my boat breaking so offen, has anyone replaced them with something better?
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Adjustment is key if this is your type of latch
Don, I have replaced a few of those myself on both the fridge lid and cabinets. They are very sensitive to the positioning of the "catcher" side so that the catch doesn't close prematurely. Once I read over this literature (attached - see p3) and understood how to adjust, I haven't had a problem for several years.
Also our fridge lid had two latches side by side and I ended up just leaving it off when I couldn't get it adjusted like I wanted. The heavy lid seems to stay closed just fine and it's easier to open.
930
Thanks. But is isn't like there really is much adjustment possible (maybe 1/64" of an inch). The other problem of course is that you really can not see the alginment.
I know that it does ake a difference as to whether I can them as everytime 1 breaks it results is the lid not really staying closed as tight and the freezer ices up.
Jun 1, 2009
1,852
Hunter 49 toronto
On my 40.5, I stopped replacing the top catches
I read somewhere that gravity was known to be reliable, and didn't need batteries.
Never had a problem with the lid.
If it really bothers you, put in either:
A magnetic catch
The brass spring loaded door catch which works at various entry angles.
Replacing the southco latches just ate up epoxy & my patience
