Steve Stoneback
My fridge runs for hours before it shuts off. Gets down to about 28 degrees inside according to my digital probe well away from the evaporator. Doesn't matter if the stat is set on 1 or 7, it just keeps running. I can turn it to the off position and it will quit. When it finally does shut off it is off for many hours until it gets about 41 degrees and then turns on again. My assumption is I have a bad stat. Has anyone had a similar problem? and if so, did a new stat fix it?sps
