Hi there,
First time poster (however I suspect this will be the first of many posts asking for help!)
I have a Waeco/Adler/Barbour fridge on the boat, not sure the model number of the unit, but I've attached photos. It's one of those where there is a cooling plate in the fridge and a compressor and fan in the stern (in the lazaratte?).
When we came back to the boat after not being on it for 4 months, we found the fridge wasn't working. On closer inspection the 5A fuse had blown in the PC board on the compressor unit. So I replaced it and the fridge started working again. Great, problem solved.
However, after 5 days the fridge was getting progressively warmer. So I checked the fuses again and this time the 15A fuse had blown.
I replaced it and watched to see what would happen. Basically the unit starts up, the compressor starts making a noise, which gets a bit louder and faster, then shuts off and on the PC board the LED blinks once. I've also never seen the compressor fan run.
After a couple of minutes this whole process starts again. We've also noticed that the cabin lights have been flickering every now again, which turns out coincide with the compressor shutting down.
The PC board says that it could be a number of things and this fantastic website says that it's almost certainly low voltage:
http://www.alliedseawindii.org/kbase/equipment/galley/refrigeration/adlerbarber.html
However, we're a bit clueless on how to proceed from here. Are the batteries dying? They are 3 year old marine gel batteries.
Any advice gratefully received!
Thanks,
Marc
Thanks,
Marc
