Fridge capacity for a1997 H430
11
Hunter 430 Mooloolaba
I have a 1997 Hunter 430 running the original Grunnert 110v refrigeration system.
I am converting to a 12V ozefridge and am trying to work out the capacity of the fridge and freezer cabinets.
I have tried to measure them up but there is hardly a straight line inside the box. I think it was designed by Picasso.
My calculations seem to be a bit excessive.
Can anyone give me the correct fridge and freezer capacity of a 1997 H430?
Litres would be preferable.
Jun 6, 2006
6,990
Check the data panel on the 120 volt compressor. It should have how many BTU the unit can handle. Could also be in the manual Buy the new 12volt unit for the same rating.
Are you intending to reuse your evaporators? Do you have air or water cooling for the condenser? Air is great (no salt water pump and the accompanying hassle) but water is better if you live "down south"
Nov 1, 2011
11
I have a water pump and I am replacing the whole system.
All of the plumbing is there and it's a great setup but its getting old and the 110v drags a lot out of the batteries.
I live in Queensland, Australia and it's always sunny and warm
