I filled the water tank, and when I turned on the pump, it didn't shut off as quickly as usual. Upon investigation, I found fresh water running from the compartment under the sole, in front of the engine compartment into the adjacent compartment, then to the bilge, where it was being pumped out. Before I begin removing everything to get to the hull, I'd like to hear from anyone else who might have had this problem. I'm thinking it could be a pop-off drain or some other drain from the water heater, which is in the aft compartment on the port side of the cockpit; the area under the water heater is dry, as is the area under the engine. Any advice is appreciated from someone who knows more about this particular system than I.
