Prepping
Just thought I'd throw this in. Don't sand before dewaxing. It just moves the wax into the gelcoat. Cheap dewaxing can be done with a solution of amonia, and a dash of dish washing detergetnt in a bucket of warm water. After washing it down with this you can sand. To make sure all of the wax is gone, after sanding wash her down again with the same solution and rinse well. If you really want to make sure it's wax free then you can wipe her down with acetone and clean rags for one last prep. then put on your barrier coat. some people don't like using the acetone because it can soften the gelcoat, but even if it does, it will only make the connection between the gelcoat and the barrier coat that much more bonded. Barrier coat is not bottom paint. It is a barrier between the gelcoat and the water. As far as bottom paint goes, I find that almost any bottom paint works in fresh water, while you do need more anti fouling protection in warm salt water. I like the ablative paints that can be out of the water with out getting too hard. Like Pettit Hydrocoat. These paints don't need sanding to put the next years coat on. If enough is left, they don't get too hard sitting out of the water and you can even skip a year of bottom painting. It even works when you trailer the boat. All of the bottom paints have a time period they need to dry before putting the boat in the water for the paint to dry. And many have a maximum drying period before the paint gets too hard to work. Ablative paints don't have to be sanded. Just power washed to ready for a new coat. Sanding bottom paint is a nasty job. The paint is toxic! That's what makes it work.
