Our 34' sailboat has a 75 gallon fresh water tank. We don't generally use the water for drinking, although a sip here or there does occur. Instead, we'll use it for doing dishes, brushing teeth, and little things like that. Last weekend while on the boat my wife developed an unusually bad case of diarrhea and associated conditions. While I had no problems, we're concerned that our water tank might have developed a bacteria, although we've experienced no indication of any problems until now. I've read Peggy's directions for recommissioning a water tank, and I'm inclined to do this since I never have, but before doing so I would still like to know more about the actual condition of our current supply of tank water. I've looked for companies where I can get a water sample tested, but not really found any that seem to fit this need. Has anyone ever done this before - and if so any recommendations? Same questions regarding those do-it-yourself test kits that supposedly allow you to test water for bacteria and other things.
While I know doing the recommissioning is still a very good idea, I've noticed this requires filling and emptying of the water tank several times before the process is completed. Since we're on water rationing in Northern California due to a dought, I'm a bit hesitant to waste around 300 gallons of water right now. Then again, I would like to know if my water is generally usable without having to boil it.
I have no expertise in this field, nor am I scientificly inclined, so I welcome any thoughts or suggestions...
