Saturday I filled the freshwater tank on my '76 Cal. I filled it right to the top. Of course when I put the cap back on the fill bung I discovered that the threaded bung molded into the tank was breaking around the threads. It's nearly 40 years old and looks to be at least partly caused from over tightening the plug. The tank and fill access is under the v-berth, it takes running a hose to the fill neck to use. Removing the tank for a replacement would be a major undertaking requiring a nearly complete tear out of the V-berth area. Is there any kind of replacement type fill caps that can be installed from outside the tank? I have limited clearance from the tank top to the v-berth floor, probably not more than 1.5" or so. Current access to the tank top filler neck area is pretty limited but could be enlarged some if needed. I've been searching the web but not entirely sure what I need or if what I want exists.
Sailing with 20-25 deg of heel later that day did give my forward bilge areas a bit of a freshwater rinse though.
