Fresh water tank cleaning
23
Catalina 30 Columbia, S.C.
What is the ratio of chlorox to water to clean the fresh tanks? I know the proceedure but have lost the ratio.
May 6, 2004
916
Hunter 37C Seattle
Monty, Peggie has posted
the entire recipe a couple of times with the bleach and viniger method. Do an archive search before Peggie yells ( quietly) at you.
Oct 17, 2005
119
Catalina 30 Edmonton
Love you guys
I love this forum. If I wonder what the answer is to a question I have and wonder long enough, sooner or later someone asks the question. Thanks for asking this one
Jun 7, 2004
944
Birch Bay Washington
Chlorine bleach is not good
for your aluminum tanks or water heater. Check the archives. I won't belabor the point here. You could use a similar amount of peroxide and do the same thing without the ensuing corrosion, salt, etc...
Dec 2, 1997
9,011
- - LIttle Rock
And if you do check the archives...
You'll see that the only posts railing against the use of bleach to recommission a fresh water system are Patrick's! :)
J.B.Dyer
Bleach User
Here's the deal. I have a 1983 boat with the original water heater. Granted, I have plastic water tanks, but, I've been using bleach to recommission my water tanks every season and it hasn't hurt anything. My water is fresh and has no odor, never has, and I suspect never will. Luck!!
Jun 7, 2004
944
Peggy, its a dirty job
but somebody has to do it. Actually, I have talked to several people who know more about it than I do and they agree but nobody wants to argue with you.
Ross
Jun 15, 2004
14,693
I treat my water tanks
in the same manner as the swimming pool. A good shock treatment of chlorine, several rinses and I am good for the season. The chlorine will burn out whatever has been growing in the tanks and when it is well rinsed out won't pose a threat to the people that drink water. Test as you would for chlorine in the pool.
- - saskatchewan
bleach user #2
1:99 for general disinfecting 1:49 for heavy duty disinfecting . i don't know why they don't just round out the ratio's but thats what i was told many years ago . don't leave bleach solution in contact with metal ,rinse well . these ratios are for standard household bleach (5%sodium hypocloride(sp))
Dec 2, 1997
9,011
- - LIttle Rock
If you're only cleaning the tank, not the plumbing too...
you're only doing half the job. Although most people think only in terms of the tank, the plumbing is actually the source of most foul water, because the molds, mildew, fungi and bacteria which cause it thrive in damp dark places, not under water. Many people—and even some boat manufacturers—believe that keeping the tanks empty reduce the problem, but an empty water tank only provides another damp dark home for those “critters.” To do it right, use a solution of 1 quart bleach/50 gal water....fill the tank, then turn on every faucet on the boat. When the water coming out smells strongly of bleach, turn off all the faucets, but leave the pump on to keep the system pressurized so the solution stays in the lines. Leave it in the system for at least 3 hours, but no longer than 24 hours. Then drain the tank through every faucet on the boat. Fill the tank again with clean water...drain again through every faucet. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar/five gallons water and allow this solution to agitate in tank for several days. Drain through every faucet, then flush the system with clean fresh water. This will also get rid of any anti-freeze taste/smell. People have expressed concern about using this method to recommission aluminum tanks. While bleach (chlorine) IS corrosive, it’s effects are are cumulative. So the effect of an annual or semi-annual "shock treatment" is negligible compared to the cumulative effect of holding chlorinated city water in the tank for years. Nevertheless, it's a good idea to mix the total amount of bleach in a few gallons of water before putting it into a metal tank. Be sure to turn off the water heater at the breaker before beginning the recommissioning...do not turn it on again until recommissioning is complete. An annual or semi-annual recommissioning according to the above directions is all that should be necessary to keep your water tasting and smelling as good as anything that comes out of any faucet on land. If you need to improve on that, install a water filter. Just remember that a filter is not a substitute for cleaning out the system, and that filters require regular inspection and cleaning or replacement. To keep the water system cleaner longer, use your fresh water...keep water flowing through system. The molds, fungi, and bacteria only start to grow in hoses that aren't being used. Before filling the tank each time, always let the dock water run for at least 15 minutes first...the same critters that like the lines on your boat LOVE the dock supply line and your hose that sit in the warm sun, and you certainly don't want to transfer water that's been sitting in the dock supply line to your boat's system. So let the water run long enough to flush out all the water that's been standing in them so that what goes into your boat is coming straight from the water main.
Jun 7, 2004
944
It is not the stupid chlorine
it is the pH, stupid. That is what is corrosive. The statement about cumulative effects is simply wrong. You guys can do this procedure if you want but those of you who have aluminum tanks can expect to see little floating particles of the aluminum salt that is what used to be the inside surface of your tank. These particles are more apparent when or rather after you agitate the tank. Or you can do what I did and cut an access hole and see the salt buildup inside the tank. It is quite amazing to me that some people are so dense as to continue to use this procedure.
