Fresh Water pvc connectors
21
Hunter 33 Sea Harbour Marina, Oriental, NC
Does anybody know where I can acquire a couple of the connectors, elbows and tees for the fresh water system? Also, is it 1/2 in or 15mm?
I have a leak in one of the connectors on the output side of the hot water heater. Unfortunately I didn't get a good look at it this past weekend.
Thanks,
Mike Oatsvall
Four Winds, Hunter 33
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
They're made by Sea Tech, white is 1/2", black is 15mm. If you have black fittings they're metric.
I'm assuming you have the quick connect fittings. If you have something else give Hunter a call and ask them.
Oct 30, 2006
21
Yes, these are the black ones.
I appreciate the information.
mike
Dec 2, 1999
15,184
Mike:
Contact Hunter Marine. They can either sell them to you (usually the best price) or give you the brand name so you can purchase them locally. This stuff is quite often the same as what is used in RV's.
