Does anyone know what type of pump the fresh water pump is on a 1983 Hunter 31?Gone and very much missed. Need to buy a replacement, but what one?Thanks in advance for any assistance.
Perry:Have had a couple on our H'31. Would look for a good quality one that is quiet. You don't need a lot of PSI, you only have the two fixtures and probably not using them at the same time anyway. If you crawl into the pit the mfg's name is on it. If you purchase the same mfg. you will probably not have to worry about changing the fittings.
