Mitch
As we were buttoning up after a recent weekend aboard "Symphony", the galley/head pump on my 1980 Cherubini 33' suddenly and with no warning, kicked off the breaker while my wife was washing her hands. There was no prior warning of a problem and no immediately obvious reason. The pump sounded normal; it simply stopped. This is the original ShurFlo water pump, in the original configuration as installed by Hunter. There have been no changes or additions to the system. I am also the original owner of the boat, so I am sure of that fact. My first assumption was that either the pump compartment was flooded from the recent rains (happened to me 18 years ago) or that the pump inlet was clogged, causing the pump to labor. A quick look and disconnecting of the inlet hose showed neither of these to be the answer. I had limited time to trouble shoot, but did determine that each time I reset the breaker, the pump ran fine (i.e water came out normally), but the time-to-kick-off was decreasing. My limited knowledge of breakers tells me that the pump is obviously drawing too many amps for some reason. On my next outing to "Symphony", I face having to trace the wiring from the DC panel to the pump to see if there is a loose/corroded connection, short or some other problem. I am not an electrician, but I can use a multitester. Any hints or tips out there as to where to start this process?
