Fresh water pump
Sep 1, 2013
53
catalina 30 suttons bay
Hello all!, can anyone point me in a direction of a good ( not 400.00) fresh water pump ? I believe mine took a poop today , I haven't thrown a meter on it yet but I think she's toast . Cheers!, SB
Shurflo. Mine's 29 years old, also have a backup. Maybe that's why. :)
Model 2.8 GPM -- Model # 2088-423-344 OEM
Backup: Shurflo 3901-0216 3.0 GPM, 55psi $98 five years ago on sale
Don't have an accumulator.
Avoid the newer variable speed ones, Jabsco for example has had huge problems with theirs, as have the C355 skippers who had them installed.
Oct 5, 2011
5
Catalina 30' Ventura CA
What year 30 do you have?
May 6, 2010
472
1984 Oday 39 79 Milwaukee
Not as lucky as Stu
I bought a Shurflo 3901-0216 in May of 2010. In summer of 2013 I had to replace it (a couple months out of the three year warranty) and also added an accumulator tank at the same time. A little over a year later, the pump did the same thing (pressure switch does not shut off and the pump runs until I tap on the pressure switch. As I did with the first one, I took the pressure switch off, cleaned everything (no evidence of anything inside that would have caused a problem) put it back together and same thing. I took it back to West Marine since it was still under warranty, and got a new pump. This week ( a little over a year since replacement) the NEW pump is doing the same thing. I have read numerous accounts online of this issue. Not sure if the solution is to eliminate the accumulator so the switch works more frequently, maybe keeping the contacts cleaner, but it sure is nice not listening to the pump run every time a faucet is opened.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
keep the accumulator...it that surflo one of the new style pumps i have heard that they do that often ...maybe change it out next time for a different brand i read somewhere in here a while back about this also there was some discussion about the pressure on the accumulator needing adjustment in regards to the pressure something about it being set at 50% of the shut off pressure at the pump
Nov 6, 2006
10,048
Usually the pressure switch is a standard part available at places like Radio Shack or on Internet. If you can get a genuine Microswitch, it may have better and longer lasting internals.
Sep 1, 2014
48
catalina 30 Oxnard CA
C 30 in Ventura with just a foot pump
what year 30 do you have
I have a '78 C30 #1249 in the Ventura Harbor in front of Island Packers.
I will be getting and installing an RV pressure pump.
The boat now just has a foot pump.
