Fresh water pump always running
cmorin
Nov 10, 2004
64
- - Falmouth, ME
I have an 89 Catalina 30 with a hot and cold pressured water system. I don't know the brand of the pump or the pressure tank but when I turn the power on to the pump, the pump will run constantly . It does not build up enough pressure to stop running and when I turn on the faucet, the water spurts out with a lot of air mixed in. It gets the entire counter wet. Is there a process I can follow to determine the issue ? Thanks in advanced. CM
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Water Pump
It sounds like the pump isn't getting water from the tank. Do you have more than one fresh water tank? I would say the tank is empty.
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
obviously a leak...
could even be a bad diafram in the pump. Refill your tank and check all your fittings.
Dec 2, 1997
9,010
- - LIttle Rock
Several possibilities
Check the line from the tank to the pump to see if it's clogged by sediment (if the tank full you'll most likely end up with a lot of water in your bilge, but at least it's clean water). Check the tank vent thru-hull for a blockage. A blocked tank vent will cause a pump to pull a vacuum that prevents anything from being pulled out of it. If you've just filled the tank, there's air in the plumbing. Leave the faucets open to spit air long enough to bleed it all out. If that doesn't work, the pump diaphragm or impeller (depending on the type of pump) has prob'ly failed. You could just replace the diaphragm or impeller, but 20 years is about the lifespan of a fresh water pump...replace it. I'd go with a Shurflo...it'll last another 20 years. 2.8 gpm is the right size for a boat the size of yours...about $80 from Defender (prob'ly twice that much from WM) and an easy swap out.
Jun 6, 2006
6,990
Air pockets
Mine did this too. Put towels in the salon and head sinks and fill the water tanks. Turn on the cold water tap in both sinks and let her run till all the air escapes. Then turn off the cold and turn on the hot and repeat. The air in the lines is causing the pump to pump air which it is not designed to do so it just keeps trying to build up the pressure.
Joe
check all fittings
Happened on my Catalina 30. Sometimes even an air leak that does not look like a water leak can be the problem. Tighten all clamp fittings and look for weathered hoses. At least you know your pump is working! Good Luck!
Dec 3, 2003
2,101
Sounds to me...
...like the water tank doesn't have enough water in it. :eek:
cmorin
Nov 10, 2004
64
- - Falmouth, ME
Wow !!
Thanks everyone, I cannot wait until Saturday to try all of the suggestions !! If there are anymore keep them coming. CM
Dec 2, 1999
15,184
Happens when we empty the tank too.
CM: This happens to us too if we empty the fresh water tank. You need to prime the pump again. Once the pump is primed it should start pumping and stopping correctly. If it continues to cycle, you probably have an air leak or you have a bad pump. Depending on the age of the pump, you may be better off replacing it. The new VSD pumps are very nice an quiet too.
