Fresh water intake on a 1978 Hunter 27
2
Hunter 27 Mayo, Mariland
Hi Folks,
I just purchased a 1987 Hunter 27 and cannot locate the fresh water intake for the water tank. I want to fill up the tank in order to use the marine head etc. Thank you for your help.:confused:
Apr 22, 2012
2
Hunter 28 Barnegat, NJ
Hi Folks,
My Hunter 28 requires you to lift the hatch under the v-berth cushions and unscrew a plug in the top of the tank. Hose through the foredeck hatch.
Jun 21, 2009
110
Hunter 27 Sparrows Point
Check for a thru-hull seacock under the starboard side salon seat. Mine uses a pump, that legally, we aren't supposed to use anymore in the Chesapeake. And honestly, the boat smells a whole lot better is you don't use sea water to flush.
Dec 8, 2008
96
Hunter 27 Deale, MD
Inside the anchor locker is your best bet. That is where mine is. Saw it yesterday while painting.
