fresh water hose location from f/w tank
C
carol
I was wondering if anyone knows where the hose leads out of the f/w tank. I have a little water that sits on the port side of the mast step next to the compression post. The puddle seems to be coming out of the side wall, not the post. I thought maybe the hose from the fresh water tank passes by this side deep in the wall or somewhere and maybe is leaking??? Any ideas would be greatly appreciated. Hunter 33' Thanks
Peggie Hall/HeadMistress
If you had a fresh water leak...
The level in your water tank would be dropping...that's the only place the water could be coming from. So before you start taking things apart, fill your water tank completely--to overflowing...don't use any water at all for at least a week...and then see if you can add anything to the tank. If you can't add even a gallon or so, you don't have a plumbing leak.
Bruce Z
Tast it!
If it's salty it's not fresh water and you can look somewhere else.
