I was wondering if anyone had any tricks for draining the fresh water system on the 3YM20. When I did it I sucked the coolant out of the resevoir and the heat exchanger and then I opened the drain located on the starboard rear of the engine. There is a 90 degree tap with a very short sleve on it to which I would have liked to attach a drain hose but the space between the end of the sleve an the engine block is too small to attach a straight hose. I had to open the tap and drain the coolant from the fresh water loop into the bilge under the engine and pump it out from there. Are there better approaches?
Gary
Glory Days
C309 # 136
Gary
Glory Days
C309 # 136
