Freezing problem in ballast tank Hunter 26
Tom
I have just bought me an 1996 hunter 26 and have launch it in seawater. Has anyone gain experience with freezing in the ballast tank filled with seawater? How low can the temperature go before i got any problems?
MABell
Dec 9, 2003
232
Hunter 26 Orygun
Might check the archives
There has been numerous posts on this. Personally, for salt water to freeze inside a ballast tank that’s surrounded on most sides by water, it would have to get cold enough to freeze the you-know-what’s off a brass monkey (where did that phrase ever come from?). But, if you live in some place like Nova Scotia – it could be a concern. Since the boat is in the water and assuming at dock – you could run a heater to keep the boat at say 40 degrees. Then, the only way for it to freeze would be for the surrounding water outside to freeze solid.
