I have a h40.5 with a separate A-B unit for the freezer. This unit uses a cold plate for cooling. At the lowest temp setting and with no openings of the top lid, I can only achieve about +10 degrees F overnight. This temp is measured in the box about half-way down the cold plate.This is OK for keeping ice and foods that are previously frozen, but it will not keep ice cream. Bagels and bread products don't really freeze either. I have put a blanket of plastic bubble packing sheeting over the top of the contents and the the cold plate and that helps, but I am still no lower than +8 degrees.Shouldn't I be able to drive the box to zero degrees F?The box is located next to my refrigerator and is not near any heat source. I would like to think Hunter used enough high-quality insulation, but I really don't know.
