To free or not to free
Dear Charlie, Thanks for your note. Ernie is correct, in some cases the act of freewheeling the propeller can and will cause undo wear and possible damage to a transmission. Most mechanical transmissions only lock up in reverse gear. Locking the transmission in reverse, depending on the speed and the load produced, could have a wearing affect to the locked trans. If the transmission is left to freewheel under sail, lubrication may not be taking place. Most transmissions are not oil bathed gears, but lubricated by a pump, which is activated when the engine is driving the transmission. You may find looking in your transmissions instruction booklet that if the transmission is freewheeled more then X hours the engine needs to be started and the transmission rotated for X hours in order to re-lubricate it. We at PYI believe that the “to freewheel or to freewheel” is driven by the vessels speed at that given time. We believe that the propeller should be freewheeled up until apx. 4 knots. Any speed after that, the shaft should possibly be locked down. As the vessel speed increases the shaft rotation will begin to slow in proportion, causing it to create greater drag. At some point in the boats speed the drag of the transmissions bearings, shaft bearings and water flow efficiency will slow the prop shaft down thus slowing the boat speed down.Hope this helps.Kevin.
