Freeing rusty bolts - best penetrating oil
Jun 14, 2010
2,417
This is an interesting test. Bottom line - when turning a rusty bolt heat is best, but when you can’t use a torch Liquid Wrench is better than the other products tested. I was disappointed by the P-Blaster results- it’s always been my choice (and I own 2 cans). Of course, there are also nut splitters when you need to free a nut (not turn a bolt).
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
I have seen similar test before.
The number one in that test = Brake Fluid.
#2 = Deep Creep by SeaFoam.
Never use Acetone.
2 more issues
1) This is Iron to Iron corrosion.
2) How about Iron to Aluminum?
3) It takes many hours and repeat applications to assure penetration of any Penetrant.
But here is the updated version
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
I read a test (don't remember where) but their first pick was 50/50 acetone and transmission fluid.
Have used most of the suggestions above. Also have had to resort to a nut splitter if there is room. Otherwise I drill a hole down thru the nut parallel to the bolt and missing the threads on the bolt. Start small and enlarge as needed. Final removal is using a cold chisel.
Sep 11, 2013
248
Catalina 25 6106 Lake Erie Metro Park
If it’s possible to use heat, try beeswax (not canning wax or candle wax)…pure beeswax. I was skeptical at first but I’ve become a believer.
Tom G
WayneH
Tartan 37 287 Pensacola, FL
I've tried WD-40 and PB Blaster and was unsatisfied with the results. I freed up a set of needle nose pliers with Corrosion-X and it's my goto spray these days. Yes, it still takes time to get full penetration but it is the best I've found so far.
While recently taking my 1973 Perkins 4.107
apart so it could be removed from the boat, I used PB Blaster on a few of the rusted fasteners. It worked but the fumes made me gag and persisted from to many days. I replaced the PB Blaster with Deep Creep Penetrating oil. Much more forgiving and usable product. (IMO)
Sep 24, 2018
4,007
Catalina 30 MKIII Chicago
Here's the source: OT - Penetrating Oil
Nov 23, 2022
25
jeanneau 389 Toronto
I don’t believe you can give a proper answer until you know what material is the bolt made of and what is it bolted to.
if you add penetrating oil to a stainless bolt stuck in aluminum if will do nothing. Enough penetrating oil left in a stud hole will compromise the locktite.
Id guess most stuck bolts on a boat are stuck in aluminum or cast iron. Cast iron being out long obsolete transmissions and engine blocks. Sailboats seem to be the last vehicle who regularly use cast iron anywhere.
aluminum with a stainless bolt fused in it diluted drain cleaner or any mild alkaline will break the bond. Penetrating oil or heat will make it worse.
pS WD40 sucks in dirt and is a poor lubricant. Pure marketing
