Hi, on our 05 H38 i am trying to fully understand the wiring and charging systems by looking at the schematics and following or trying to follow what I am seeing to better understand how things work. We have the inverter option so i assume from prior experience on shore power in charge mode the house battery (4D) is being charged and the start battery is being charged by the echo charger function of the Freedom 20. When i put a tester directly on the house battery it is clearly being charged showing 14.x V in charge mode. When i put the tester on the house battery it is not being charged - showing 12.5 or something similar. When i have engine running the alternator charges both batteries. The wiring diagrams do not show the circuit for the Echo charge, and when i follow the wire from the echo charge output , under the floor board to the battery compartment and up into the space under the nav station it appears to join a bundle that heads up to the AC or DC panel area and this is where i am not understanding why this could be. Should this not be connected to the start battery switch somewhere ? Thanks ! Rob
