Bob La Salle
My engine (Yanmar 2GM20F, 1985 Hunter 31) quit suddenly yesterday, just died from 2000 rpm to zero in a few seconds. I immediately suspected a fuel problem but had changed the primary filter last August (it was a mess) and secondary filter (absolutely clean) three weeks ago. When I removed the primary filter yesterday, it was loaded with water. Replaced it and bled the line, and the engine is fine again, although it passed a lot of white smoke (water vapor) for about 10 seconds after it started. I top off the fuel tank before winter storage, to reduce water condensation inside the tank, but I only burn about 10-15 gallons of fuel all season so I never really empty the fuel tank of old fuel.Questions for diesel owners: what fuel additives do you use or recommend - biocide, conditioner, stabilizer, other? How often do you check or change your filters? Do you drain out the water from the bottom of the primary filter on any regular basis? When this is done, is it necessary to bleed the fuel line? Has anyone had their fuel tank pumped out, and what is the cost for such a job? Can I bring my fuel supply "back to life" by treating it? Any other recommendations?
