Found This Oil Changing Idea, Looks Useful
Jun 14, 2010
2,411
Clever idea, but it will be messy if the receptacle goes sideways. Also, not very portable and requires nearby power. I typically do my oil changes on the mooring and use one of those vacuum pump extraction containers. Something like this (I use a different brand, but they all work the same):
Feb 17, 2006
5,274
Looks safer than what I did. I used an old 12vdc fuel pump with tube to drain the oil in my dinghy outboard. It worked great but I think it was dangerous to do it that way. But it worked. Now to spend money on a dry vac. LOL
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Very clever and practical!!......However, I will stay with my 6.9 quart manual vacuum oil changer from West Marine since my oil capacity exceeds a standard 4 quart container I would place in the shop vacuum, it is equally quick and I can view the oil level in the container while vacuuming out the oil.
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
Why don't they just do a double lined garbage bag inside the shop vac?
I have one of the WestMarine Oil changers, shown above.
Jim...
JamesG161
Feb 14, 2014
7,935
Jun 14, 2010
2,411
Because you can take a sealed container by car to a recycle depot and it can be neatly handled and transferred into larger tanks. How do you transport and handle oil filled trash bags without leaks and spills? .
JamesG161
Feb 14, 2014
7,935
You cut off the top of the big container that collapsed. Insert garbage oil fill bag and take it the same way.;)
I actually use my oil in specific legal spots that need it or take it to my landlubber oil change spot and they take it.
Jim...
Jun 2, 2004
3,607
Jim...
I thought about that too, also add a bag of kitty litter to the shop-vac and eliminate almost any chance of a mess.
  • Helpful
Likes: JamesG161
I had an older version of this and it worked great. Very easy to use. The pump creates suction and near the end you can move it around the crankcase to more fully empty the oil. Then the container goes to the recycling. No mess.
Dec 28, 2015
1,923
Done it a couple times with my ski boat before I bought a extractor. I got the idea from a medical suction unit.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Time out. Before we get carried away, shop vacs aren’t intrinsically safe. There’s always one Darwin specialist who will eventually try sucking gas and get blown out of his garage. Don’t be like Dave.
Nov 22, 2011
1,277
Ericson 26-2 San Pedro, CA
Didn't the video specifically warn against doing that?
Likes: LloydB
Dec 28, 2015
1,923
Thins the herd....
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I've been using this with a 2-liter coke bottle for collection. It's going on 3 years now with no problem.
Jun 2, 2004
3,607
Also considering using this method on our coach boat outboards.
Attach a funnel to the end instead of the hard plastic tube remove the drain plug hold the funnel under the drain and voila. Also for the foot oil attach the filler hose to the drain port of the foot and to the vacuum then remove the other plug no dripping oil at all. We've got six different boats to perfect this scheme on I'll report back in a few months on it's efficacy.
Jun 2, 2004
3,607
I also have an old shop vac that the motor is dying on a 100' extension cord and some old gas.
Wanna bet if it'll light off? While probably not inherently dangerous it does border on colossally stupid. Would have made a superb Myth Busters segment.
