Found this lurking in my files and can't resist sharing it
Dec 2, 1997
9,011
- - LIttle Rock
TOOLS EXPLAINED
DRILL PRESS
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh --'
SKIL SAW:
A portable cutting tool used to make studs too short.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
BAND SAW:
A large stationary power saw primarily used to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on liquids in plastic bottles and rubber or plastic parts.
Nice one, Peggie.
Merry Christmas
JamesG161
Feb 14, 2014
8,015
Hunter 430 Waveland, MS
Add this to your list of tools needed.
Fun tool for the handy fixer.
Jim...
Rick D
Jun 14, 2008
7,201
Hilarious and painfully accurate.
