John
During this winter's lay-up, a tiny crack opened up at the upper edge of my H31 bilge sump. About a tablespoon of smelly coffee colored water has slowly trickled out. Because he boat is tarped over (and dry) for the winter and the water has a nasty odor, I think that this is old water trapped in the hull.The tiny crack is along the meeting line of the sump's hull/liner join. I think that the coffee colored ooze is long-ago water trapped in the infamous little compartments between the hull and liner on the H31 models.I'm considering establishing weeping holes in that area (both upper sides of bilge sump). I'd also consider injecting some bilge cleaner (or ????) into the weeping hole to flush the area.Has anyone addressed this issue, or have ideas?
