Forward/neutral/reverse
Jul 29, 2013
10
Hunter Hunter 376 Guayama
Hi, I own a Hunter 376 1997 sailboat. I will like your recommendation. When I am under sail power and my engine is off, I have the transmission on reverse gear. Please provide your comments. Thanks.
Catalina 320 Dana Point
Depends on transmission, Yanmar specifies neutral for kanzaki transmissions, Most Hurth transmissions spec neutral or reverse.
Likes: Rick D
Rick D
Jun 14, 2008
7,207
The standard response used to be reverse. But Yanmar issued an advisory several years ago and Calif Ted nailed it... most likely neutral for your boat. The archives have plenty on this. Enjoy!
Jul 29, 2013
10
Thanks I will check on transmission model and or specs. My motor is a Yanmar. If the transmission is set on reverse to start up the engine the only way is to start it on reverse. It will rotate on reverse will the boat is doing 6 knots.
Apr 11, 2010
998
Hunter 38 Whitehall MI
Run a search in the archives. There are dozens of posts on this subject. Including in the posts is a bulletin from Yanmar that addresses this topic.
