forward is reverse and reverse is dead...sometimes
K
Kevin L. Woody
Hum
Hello Jim, I’m afraid that you have stumped me! Any comment on my part as to what it could be, would be bamboozle on my part. This is Voval’s web site http://www.volvopenta.com/t/001.asp?id=1
G
Garry @ S/V TASHTEGO
Shifting
There are two possibilities for your problem. The first is that there is a fault in your transmission - bad news and I can't help you there. The other is more likely. If the sheath on the shifter cable has come adrift at either end the cable will not work properly as it has nothing to pull/push against. This can be hard to find as it is not obvious if the sheath is unattached. I assume you have checked that the cable itself is firmly attached to the levers at both ends. To check the sheaths, watch the end of the cable where it emerges from the sheath, first at the cockpit lever end then at the transmission end to see if it moves when someone else moves the cockpit shift lever back and forth. On TASHTEGO the shift and throttle cables are retained in the back of the cockpit lever assembly by brass pivoting clips with a little dimple detent to keep the clips closed. I have knocked them off loading and unloading the port cockpit locker once or twice (both times the throttle cable sheath) and the lack of control is eerie. The lever moves but sometimes something happens and sometimes not.
Dec 2, 1999
15,184
I like Garys idea.
Jim: I like Garys idea. I think you should try moving the tranmission lever my hand and see if it shift in/out of forward and reverse easily. Then do as he suggested and try it at the pedestal/throttle control. If it is okay doing it at the tranny, then there is a good chance that one of the points where the sheath for the cable attaches came loose. I think that some of them have a point at the throttle location and another at the engine/transmission location.
Jim Cook
Thanks Gary!!!!
You put a ;>} on my face. The end of the cable at the transmission was loose. I tightened it today. I haven't left the dock yet but I shifted between foreward and reverse several times and it worked every time. Thanks again, Jim
