trey261@aol.com
I have a hunter 410 '00 and the forward holding tank under the forward bunk has a bad urine smell to it. We contacted hunter and they said it is suppose to have an odor to it but there is no way it is suppose to smell like that because the aft holdind tank doesn't smell at all. There was a small leak in the sensor but we had that replaced and it only showed up because we filled the entire tank up. Outside of that there was no other leaks that we could see.thank you
