Forward Hatch Screen
Dick
Easy and economical. Open the hatch and have someone hold a piece of cardboard up against the opening. Trace the the inner lines of the opening and make a pattern. Lay the pattern on a small piece of nylon screen material, mark, and cut out. Use 3/4 inch, self adhesive velcro . Stick hook side around the edge of the screening. Stick other side around inside edge of opening. Works great.
Brigg Franklin
Tape the edges
You might want to consider taping the edges of the screen material to keep it from un-raveling. I did an article with picture, which is in the archive (see link). When you pull on the cut edge of the screen to get it off the velcro, the light plastic material can tear. Brigg
