Forward hatch replacement
143
Hunter 27_75-84 Atlanta
Any idea where I can get a replacement hatch for a 1978 Hunter 27? It looks like it isn't quite square (more narrow in front than back). Is it made by Gray Industries like the portlights are?
Jun 5, 2004
160
Hunter 27_73-83 Harrington, Maine
Search for Trapizoial Hatch
Chuck Fort (I think) did a piece on his boat. There is a picture with the Bomar hatch number right on it. I did it myself last year. I takes a while to get the hatch from Bomar. Randy
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
Bomar 2092
Here is the link to the photo article. We did it, too - a great improvement. David Lady Lillie
H
Howard
Had the same did the same
I had the same problem. The trapizoid hatch finally gave out needed to be put to rest. I replaced it with a Bomar hatch. Needed to square out the opening(turned the trapoizshape to a square)with a saber saw. Used Bondo to fill the edges and painted the inside edges white rustooleum paint. I used caulk to make a nice bead in the inside corners. I think I used 5200 on the outside flange of the new hatch but don't remember. I also used screws on the flange in the predrilled holes. Looks just like the pictures in the other post. Not to difficult. Came out great and took about a day. Have fun.
Jun 27, 2005
143
Thanks
why is nothing easy anymore? Thanks for the input, I guess I'll get out the old grinder and order the bomar hatch
Jun 2, 2004
425
Bomar 2092 _is_ trapeziodal
No need to grind - the 2092 is pretty much a drop-in. David
Jun 27, 2005
143
What the... ???
OK, now I'm confused. David says it's pretty much a drop in and others are saying you have to grind 1/8 on the side and 1/4 on the rear.... (or something like that)? Can there be that much differance between 1974-1984 Hunter 27's?
steve rainey
hatch
just curious why would you have to replace a hatch? Can't they be rebuilt pretty easy? Are they the same as a H30 1978? Sailors Exchange in St Augustine has hatchs that look like the ones on mine..
Jun 27, 2005
143
why replace
The boat is old (1978) and the plastic frame is beginning to crack. also, the bracket that holds on of the dogs has cracked and been repaired with epoxy and the port side support (that holds it up) is missing.
