Forward hatch replacement
  • Thread starter Brian & Jennifer DeVito
  • Start date
My forward hatch needs to be replaced on my 1986 28.5. Any ideas where I can buy a replacement? Thank you! Brian & Jennifer
E
Eugene Meskyy
lewmar
I am planing to do the same. Bomar and Lewmar hatches should fit the hole. Bomar Low Profile Extruded Hatch 20x20 And Lewmar 60 low profile But you will need to check if they will fit the hole. Sailnet.com Bomar Low Profile Extruded Hatch 20 in. x 20 in. BOMN1039-10A On Order $241.95 Lewmar is more exp. about $350-$400
Peter Roach
What is wrong with the old one?
If it is cracked then you need to replace it, but if it is ulgy (the plexiglass) try a little rubbing compound and then wax. Do both the inside and outside. You will be amazed at how nice you can make an old hatch look.
