I need to replace the forward hatch on my S2 8.6 meter. As you know the hatch is an unusual configuration and standard hatches wont fit. Does anyone know where I can get a replacement? Maybe from a custom shop?
i am replaceing mine with a bomar cast aluminum hatch .....the clear opening on my hatch is 19.5 inches and the bomar fit it perfectly...as for the out side flange it fit the deck surface perfectly as well ....i scored it of a morgan motor sailor from a slavage yard in texas i am haveing it anodized black and putting a new lens in as well...you can bed it with mainesails bedding compound tape...if you are concerned about the 2 groves for the gaskets of the original ...just fill them with thickened resin and fair smooth...fasten it down with the proper ss screws....if you woud rather replace it with the same as it came from factory ....contact AIN plastics in Georgia and have them make you a new one using your old one for a pattern or send them a drawing ...they may have a drop in stock they can make it out of......hope this helpsI need to replace the forward hatch on my S2 8.6 meter. As you know the hatch is an unusual configuration and standard hatches wont fit. Does anyone know where I can get a replacement? Maybe from a custom shop?
Bob.....that is some very good info on the site (select plastics) about the sealants and cleaning.....Cool Woody. I can't wait to see how it looks.
If the hatch on the 8.6 is just a slab of plastic just have one made if it is an odd size. There is a place in CT that can do it for you. www.selectplastics.com
