Forward Hatch - '77 Hunter 27
Bill DuBois
I recently called Bomar to see if they had a replacement hatch for my Hunter 27. The Bomar line has nothing usable without getting into reconfiguring the hatch opening (so they say). They also said that they have none of the old original Grey Enterprise hatches left. Does anyone have any other leads I could follow?
H
HN
A new hatch:
I had the same problem with my 78 H-27. The hatch hinge broke and the cover went South (it sank). I called Bomar now owned by Pommenette and they were not really helpful. I purchased a 21" square hatch from Bomar through West Marien and planned to enlarg the opening. If you want to know the exact size e mail me at Nelsonhow@aol.com. The job went like this: I removed the old hatch trim and cleaned the area of caulk with a scraper and paint thinner. I then placed the new hatch in the existing opening. The rear fit like a glove but since the opening was trapizoidal the front did not fit. I expected this. So.. I took the new hatch out and placed it on a scrap of 1/4" plywood about 28" square. I traced the the new hatch size leaving about 1/8" additional for a router guide. A carpenters pencil gives you about the right additional space. Since the new hatch has a 3/4" trim ring you have about 1/4" inch to play with. But make the templace as carefully as possible. I secured the template to the top of the deck with 2 sided carpet tape so that the rear of the templace was 1/8" outside of the rear of the deck cut out. The rear of the opening did not need to be enlarged. Then I cut out the front and forward sides of the opening. The sides were just fiberglass and gelcoat. No structural cutting. In the front I remove a very small amount form the internal beam of the deck less than a 1/2" from the corner. So I don't think the strength is affected. I cut the opening with a 3" x1/4" carbide tipped router bit. I cut about 2/1/2" deep, enough to allow the dogs on the hatch to clear the headliner. When I was done I removed the template dry fit the hatch and relaized that I needed to go a litter deeper in the front to accomidate the hatch dogs. I cut the addition from the font without the templte. After I was done cutting I used a dremel sander and wood block to clean and sand the areas I cut out. Then I used several coats of marine paint to seal the exposed beam edge and fiberglass. Since none of the area will be exposed to the outside I elected not to use gelcoat or resin. In fact 99% of the area is covered by the interior of the hatch trim. I used 5200 caulk to bed the hatch and new stainless screws. After this was done I use more 5200 to fill the interior gaps arount the trim. I'm not much of a craftsman but my crew who are, give me a 98%. Next time maybe I'll get 100%. By the way the hatch cost $230,router but $20 (ouch but it was carbide, don't skimp here) screws $3, Caulk $8, Paint $4 (4oz of marine white touch up). It beat the cost of a new trapozoidal hatch with was $600 and would still require me to cut the deck. Total time not counting drying time about 4 hours. If you have a rounter and are a little fearless it not a big job. It was easier than making new hatch boards out of Oak.
H
Howard
PS to Billa
Just a PS: I'm still in Coney's Yard, in Huntington if you want to take a look at how I did the job.
