foreward hatch
9
Catalina 22 Independence
We are wanting to replace our old (75) leaking hatch. Anyone have any suggestions? In the catalog I am having trouble finding a size to match.
Joe
Jun 1, 2004
8,321
The standard answer is....
Call the factory. They have many replacement parts. www.Catalinayachts.com
Trevor - SailboatOwners.com
Upgrade from Cruising Concepts
Hi Bonsai - You know the old adage, "if you have to replace, you might as well upgrade!"? Although not cheap, a great upgrade is to replace your forward hatch with lexan, as provided by Cruising Concepts. See Related link below. Best, Trevor
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
Catalina Direct
Catalina Direct has the replacement forward hatch your looking for. If you don't have a copy of there hand book you might also get it as well.
Jun 5, 2004
97
- - Greenwich, CT
you gots the old boat
The hatches mentioned in the earlier replies are for post '85 boats. The one in the Catalina Direct catalog is for a post '85 boat. I do not think you can get a forward hatch for a pre '85 boat. Nevertheless, why is the hatch leaking? Is it just the rubber seal worn out that may be replaced by Catalina Direct? Or do you need to install some good dog latches to hold the cover closed. You may wish to view my method for closing the forward hatch which can be seen at: http://tinyurl.com/6bay3
Oct 21, 2004
9
Thanks
Thanks to those who helped "foreward hatch". I am still looking. Trevor, good idea!
