Forestay
ddox
Aug 20, 2025
9
Catalina Capri 18 Lodi
So, went to rig it today, and when I tried to attach the forestay it was about 3 inches too short. I tried loosening all the turnbuckles but still a big short. If I buy a quick release lever will that buy me a few inches? The backstay looks like it is kink a bit in a few places. Do I need to replace the rigging? Is there anything I can use as an extension?
A kinked stay should be replaced to make sure the wire has the proper strength. Whether that’s affecting your forestay length or what else could be affecting it is hard to say.
Likes: JBP-PA
Mar 6, 2008
1,417
If you have the original forestay, compare them with each other.
ddox
Aug 20, 2025
9
I just boat this boat, so I only have the one forestay. I suppose I could measure it vs what's in the manual. It has not been sailed in over 10 years so the stays are probably old.
Joe
Jun 1, 2004
8,260
Make sure all mast wires have been "shaken" out so there are no "kinks"... I don't mean where a wire is crimped (but that would certainly cause a similar problem) rather that they aren't twisted or unable to lay flat. Check the connections to the mast for a somewhat flat attachment, one that doesn't look twisted under itself or "out of position"...i.e. natural looking...not tensioned. Do this inspection as you get the mast ready to elevate. Just one twisted wire will upset the proportional relationship. While the mast is on the boat on the trailer in position to be stepped, with mast end connectors smoothly fixed to the big shackle and lower ends disconnected, pull each wire so that it is untwisted and free from any other impediment and lay it out flat near its boat attachment. It should just lay there untwisted. Both sides should look the same. Most trailer sailors will leave their mast wires connected when putting the boat in travel position because it reduces set up/take down time in the parking lot. This is the common time when a shackle or wire can get twisted. And YES shroud adjusters will help prevent this occurrence and make your rigging process a bit easier. Good Luck...enjoy the boat.
...Oh, by the way. If you're still having problems with this issue, you can tie the forestay to the stem with a couple windings of small diameter line so you can still get the mast up and do some sailing. Sometimes. jury-rigging in such a way can help get the kinks out and perhaps clarify the problem.......... anyway, don't be surprised if that happens. Just know that the more you mess with the gear the greater the likelihood you'll get it sorted out.... that's my experience anyway.
ddox
Aug 20, 2025
9
I may have figured out the problem, the T-bolt at the top was stuck inside the mast, which might account for my missing inches. If I'm still a little short I plan to try a toggle to give me the missing length. I guess it's all just part of the learning process!
Likes: JBP-PA
JBP-PA
Apr 29, 2022
712
Jeanneau Tonic 23 Erie, PA
If the boat used those shrouds and stays before, a 3 inch difference is definitely due to something being attached wrong, wire does not shrink like that. Check all the attachment points, post pictures here and we can help. Another common problem is a turnbuckle gets jammed up crooked which can bend them, don't try to force anything.
