Foresail (Genoa)Halyard 466
Feb 21, 2014
137
Hunter Passage 42 St Andrews Scotland
Hello out there. I've been searching the Internet for the length of a Genoa halyard that will reach back to the cockpit of a Hunter 466. Anyone know?
Top of the morning to your Scallywagger. There is a calculator here on the site. Input your boat manufacture, model number, and you able to get the company estimate.
I guesstimate about 149ft should give you enough line to make a run up and down your mast and back to the cockpit.
You can by more, which would give you a surplus to use on other projects like fenders and such, or you can buy less which means you might not have enough to reach all the way to the cockpit and have to work at the mast during those North Sea storms.
Or you can trust the calculator to give you that Goldilocks, Ahhhh. Just right, number.
Feb 21, 2014
137
okay, great I'll take a look. I've bought a cruising chute and snuffer for my 466 but, it has no halyard set up for it. Thanks
I installed a spinnaker crane on the top of my mast facing the bow and run the spinnaker and snuffer up on a block attached to the crane. This puts the halyard out in front of the forestay. The halyard enters the mast using an "exit box" and then out the same way near the deck. Installed with the mast off the boat. Pretty easy to manage all the lines running through the mast and make sure they do not conflict with anything. More difficult to do it with the mast standing on the boat and trying to accomplish it from 60 feet in the air.
Feb 21, 2014
137
okay great..I did send my drone up there to take a look..I have it figured out, its just the length of rope to get it back to the clutches in the cockpit. I tried the formula to get the length but couldn't figure out out to get it to work
When I ran the calculator on the website, the report is here.
Running Rigging Calculator
Here's the quote for your Hunter 466
ItemOur PriceQuantity
Spinnaker halyard, Samson XLS3, White, cleats off in cockpit, cleats off in cockpit
Length: 155 feet
each $230.95
Feb 21, 2014
137
Length: 155 feet
each $230.95
wow! thanks very much
