Forehatch leak
2
Beneteau First 36.7 Keyport
On my b367 I am getting a lot of water already in moderate seas. The sealing seems to be okay. Any ideas similar problems?
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
Hard to say with the little detail you provide. Maybe you could tell us what type of hatch it is and where you think the water may be coming from. There are several possibilities, I would look at the gasket and handle or latch fitting first. Maybe have someone outside the hatch spray a hose while you stay inside and look for leaks.
Beneteau 323 Annapolis MD
Are you dogging the hatch down to fully closed, or just to the "vent" postiion?
Apr 30, 2010
54
beneteau 331 victoria
I had water coming in the u-bolt fitting for my baby stay, right in front of the foreward hatch. I also had a loose screw on the rear hatch hinge allowed water to get by. Then I had water coming in the deck mounted cable fittings. I also had water coming in the chain plates. I also get water coming in the opening ports that get dirt buildup. After 2 years of chasing leaks I am leak free!!
