I came across this neat little plug-in which clearly shows the loss of various type coax cable at various frequencies.
It is worth plugging in a few of the listed types of coax to show how significant the loss can be for the type typically used by boaters vs. some of the better types.
Simply scroll to the bottom of the page, change the frequency to approx 150 MHz, estimate the length of coax and voila.
With a 100 ft run of marine RG8X and 25 watts input, the antenna will see less than 10 w. With a decent coax, e.g., 9913, the antenna will radiate twice that power.
That doesn't equate to twice the signal strength but it can make the difference between intelligibility and noise when you most need it.
Something worth considering the next time you have to call for help.
http://www.ocarc.ca/coax.htm
