Standard Horizon LH-5
We went with a Standard Horizon LH-5 loudhailer and horn - but can't remember which one. The impedance matched and it had the largest wattage output for longer life. According to the West Marine catalog the LH-5 has 20 W output at 10% distortion but somehow 40 W sticks in my mind (maybe this is at 4 ohms?). The PA horn, a rectangular Standard, is 40 watts at 4 ohms.We also bought the Horizon hailer/talkback speaker to have it at the helm but it's magnet really affected the compass so it hasn't been permanently installed yet - it's only been two years. Our compass is very sensitive, a German made Venus, and the talkback speaker still has an affect even at five feet (!).For a hailer to be useful as a hailer one really needs the mic and controls near the helm so with the head unit down below it hasn't been any use in its hailer capacity. Where we have really got a lot of use out of the LH-5 is in traveling under fog. According to the regulations one is required to sound the appropriate signals and the LH-5 makes this a no-brainer. Just poke the appropriate button for "under power", "under sail", "at anchor", "aground(!)", etc. For example, on a trip last summer out Juan de Fuca Strait from Victoria BC to Barkley sound it was foggy nearly the entire way. Our radar picked up numerous targets which were mostly fishing boats, both sport and commercial, with a few yachties and ships throuwn in for good measure. Since we stayed outside the shipping lanes the ships weren't a problem but the numerous fishing boats were. With the horn going in visibility as low as two or three boat lengths, the targets ahead of us would often just move out of the way!!!The horn is currently jurry rigged on a board which gets clamped to the pulpit seat and 16ga wire is run aft to the LH-5. This puts the horn as far away from me at the helm as possible and that way I can listen for traffic. If it is white caps it is clamped on the spinnaker pole car to get it away from salt spray. There are a number of boaters who travel in the fog without radar reflectors and with fiberglass boats and they don't necessarily show up on radar very well. In fact, I've had a small group of little birds show up better than some boats.Something skippers need to think about is what happens if there is an "incident"? In the investigation it will come out who was sounding the proper signals and if you weren't you could be in a very bad position. What good is it if one has boat insurance and don't sound the proper signals?If one has radar for use in low visibility conditions one should also have a radar reflector (properly mounted for maximum reflection), and a hailer to sound the appropriate sound signal. Personally, I'd like something with more than 40 W for when under way. 40W does not really sound all that loud. It might be able to run the LH-5 output to an electronic switch which could then actuate a louder horn, like a Marinco "full blast" air horn (121 db, self contained, $189, WM), that takes 20 amps (240 W at 12 volts). By comparison, the input of the LH-5 is 5 amps max so the output is less.A factor that will diminish the sound to traffic ahead is wind. A true wind that is against the boat's direction of travel will really reduce the range of the sound considerably, something to keep in mind when either underway or at anchor.Bottom line is the hailer and horn is a cheap investment for what you can get out of it. I think it's a good idea.By the way, I sailed in Rhode Island years ago out of E. Greenwich (sp?) in a 16 ft day sailor (Falcon class). Went to Dutch Island (think thats the name of it) a lot. Also sailed an over night trip from Pt Judith to Block Island in late September (no crowds) and the return trip was in pea soup fog all the way. Fortunately I had a compass and with luck we came back right on the breakwater for Point Judith. Lots of good memories there. Fall colors and a blue sky with cold air..nice.
