Following my own advice??????????
3,431
Seidelman S37 Slidell, La.
Was out this morning finishing up the boat. Getting ready to leave Wed. morning. You know the usual stuff. Change oil, check all the belts and hoses. Anyway I cranked the engine to warm it up for the oil change. Change the oil, and crawled around sort of down under the cockpit floor. Looking, checking, etc. So, I go to crank the engine back up, and zip. I mean NADA. The panel is dead, start switch is dead. Now I know there is something I knocked off, and my first thought is a ground wire. First I take a casual look through the inspection port. Checked the harness plugs, visually, and don't see anything. An hour later, I am going checking towards the panel, with a volt meter, looking for a bad or broken connection, that I managed to knock off. To finish out the story, I bumped the harness connector at the engine, and if came apart. What I had done was to knock it basically loose, but it didn't come totally apart. And I just made a cursory visual of it, and it looked plugged up, and I assumed it was. I know that on more than one occasion I have told others on this board to check the simple stuff first, and also to use some logic. So now, I just need to learn to follow my own advice.
May 24, 2004
7,228
CC 30 South Florida
Yes, that will do it, but them simple things
never happen to us so we have to look first at serious possibilities. But the fact that it occurred at the dock prior to departure should have been a clue that this was a fly ball. Our types of failures usually occur at sea in foul weather.
Jun 7, 2007
515
Hunter 320 Williamsburg
Don't feel bad
Last year I had two electricians puzzling why the shore power didn't work. Turns out a life preserver had inadvertently switched the circuit breaker, which is practically hidden atop the insider starboard lazerette on H320.
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
I don't know how many time I've complicated the problem...
by intense trouble shooting, when I should have looked at the simple solutions first...I always feel like such a dummy afterwords.
Jun 7, 2004
944
Birch Bay Washington
Sounds like you might want to clamp it better
If it comes apart from inadvertently bumping, it must be a loose fit that should be corrected before that happens when you need the engine most.
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
Ya ever notice..
It's always the last thing you look at ;D I feel your pain, Tim
Mar 28, 2007
211
Hunter 33' Cherubini Biloxi Back Bay,MS
Nice N Easy
Phil, Be well and safe out there. Drop us a line when you get back. We enjoyed having you over for dinner the other weekend. Sorry we missed you at Ship Island. I see you were delayed in getting out..we got stuck finishing the remodeling on the bedroom (for my Birthday :)) this past Saturday as the new furniture was being delivered in a few days and had to finish the hard wood floor and painting and such. If we don't talk to you before June 12th........Happy Happy Birthday!!!
